  • Shahid Hussain 9 posts 29 karma points
    Aug 01, 2019 @ 15:12
    Shahid Hussain
    FaLink does not work
    Hi Matt,
    I have some issues with your Bulma Start Kit.
    Everytime i run the website it gives on property FaLink. It gives this error
    But it is not null. I am just trying to run the installed package and everything i published. What is wrong?
    Everytime i click on edit i get this error
    GET http://localhost:50708/umbraco/backoffice/UmbracoApi/Entity/GetUrlAndAnchors?id=umb://document/4a1f4198e14348baa0f51a7ef2df23aa 400 (Bad Request)
    Possibly unhandled rejection: {"errorMsg":"Failed to retrieve url and anchors data for id umb://document/4a1f4198e14348baa0f51a7ef2df23aa","data":{"Message":"The request is invalid.","MessageDetail":"The parameters dictionary contains a null entry for parameter 'id' of non-nullable type 'System.Int32' for method 'Umbraco.Web.Models.ContentEditing.UrlAndAnchors GetUrlAndAnchors(Int32, System.String)' in 'Umbraco.Web.Editors.EntityController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter."},"status":400}
  • Matt Barlow | jacker.io 164 posts 740 karma points c-trib
    Oct 24, 2019 @ 14:26
    This is fixed in the latest version (1.0.6) - thanks.
