  • David Buckell 3 posts 73 karma points
    Aug 12, 2019 @ 13:15
    David Buckell
    IPublishedContent fields are null
    Hi, Have installed a clean 8.1.1 umbraco instance, set the ModelsMode to "", installed your package and published all items. On navigating to the site I get a null exception on (i believe) BlogListSection.cshtml when executing this line: var blogsNode = Model.Blog.Select(x => new Blog(x)).FirstOrDefault();
    Model.Blog is null. Other fields such as text were populated, but seemingly any fields trying to map to IPublishedContent are not working.
    Have I missed a step?
    thanks
    Aug 12, 2019 @ 16:07
    David Buckell
    ok so having attempted to install this into a 8.0.2 umbraco instance it's working straight out of the box. so i guess the answer to my question is it simply isn't supported with 8.1.1 yet?
  • Paul Sterling 719 posts 1556 karma points MVP 9x admin c-trib
    Aug 12, 2019 @ 23:13
    Paul Sterling
    Hi David -
    Indeed, due to the way the Models in the starter kit are included - in the compiled assembly - they'll need to be rebuilt against 8.1+...or that part changed to a pure Models Builder approach.
    Here's the issue logged at the repository: https://github.com/mjbarlow/Umbraco-8-Bulma-Starter-Kit/issues/2
    You can use the method that Cheryl outlines in that thread to use the current source with 8.1+, but the "best" way will be to update the starter kit to use the standard Models Builder approach IMHO.
    -Paul
  • Matt Barlow | jacker.io 164 posts 740 karma points c-trib
    Oct 24, 2019 @ 16:11
    Thanks guys, the starter kit is now updated to Dll models mode, and now works with Umbraco v8.2.
