  • Tom Madden 253 posts 455 karma points MVP 4x c-trib
    Jun 28, 2010 @ 11:50
    Tom Madden
    Alt required for Top Navigation
    Dan,
    In your Top Navigation, you're checking current() to see if you're already on the home page, but since you're not in a loop, you should be shecking $currentPage instead.
    Regards
    Tom
    Jun 30, 2010 @ 18:21
    dandrayne
    Hi Tom,
    Thanks for this.  I've kinda neglected the package as I've been creating a v2.  My main focus now is targeting 4.5 but the packager is broken...
    Hopefully I can get time to update the package for 4.0, but your post should help people with this problem until then.
    Dan
