  • tarekahf 215 posts 153 karma points
    Mar 11, 2011 @ 21:30
    tarekahf
    Some issues with Business Starter Kit.
    I installed Umbraco 4.6.1 and chose Business Starter Kit option (BSK) during the installation.
    After several days playing around with BSK and Umbraco, I find the following issues:
    - This CSS Code in custom.css cannot be accessed from back-office:
    /* EDITOR PROPERTIES - PLEASE DON'T DELETE THIS LINE TO AVOID DUPLICATE PROPERTIES */
    body
    { background-color:#333440;}
    .newsbox .feedList h4 a, #sitedescription h1, a{ color:#ec008c;}
    .primary-bgcolor, a.ui-btn-big, .newsbox .feedList h4 a:hover, #slider #imageSliderNav a.activeSlide{ background-color:#ec008c;}
    #header #mainmenu ul, #header #mainmenu ul li{ background-color:#22212C;}
    #header #mainmenu ul li.home a{ color:#22212C;}
    body
    When I created a sub CSS entry under custom.css, the above code was deleted by Umbraco. I used Notepad to verify the content of custom.css before and after.
    - Is the above CSS code needed by the BSK ?
    - In order to make to blog post work in Business Starter Kit, I have to add the following to the master page "Starterkit Master":
    <asp:ContentPlaceHolder Id="cp_head" runat="server">
      <!-- Insert default "test" markup here -->
    </asp:ContentPlaceHolder>
    Otherwise, it is failing when I click on the link of the Blog Post Title.
    Now, the blog post are working, I can post a new blog entry from the back office, but, when I try to post a comment from the UI, the page is posting back, but no comments are showing.
    I check the back-office, the content section, I don't see any document for the comments I tried to post.
    Looks like the Blog package installed is not complete.
    Please help.
    Tarek.
    Jul 05, 2011 @ 23:31
    dandrayne
    Hi Tarekhaf
    I think these posts were going into some obscure folder in gmail, sorry about that.
    For you & anyone else who finds this, I think this post is related to the installer-based business start kit, not this package.
    Dan
    Jul 06, 2011 @ 00:29
    tarekahf
    Hi Da,
    Wow .. after that long, I cannot remember the context of my issue.
    But thanks anyway for posting.
    Tarek.
  • Funka! 398 posts 660 karma points
    Sep 23, 2011 @ 04:16
    Funka!
    Hello dandrayne,
    You indicated there is a difference between the installer-based business starter kit, and this package. I have been finding a hard time finding out what the difference between the two is. They seem like they are the same thing? (But you are obviously indicating otherwise.) Is there some page which can answer this question?
    Thank you!
    Sep 23, 2011 @ 11:42
    dandrayne
    Hey Funka!
    The "starter kits" listed at http://our.umbraco.org/projects/starter-kits were mostly created before umbraco HQ rolled out the skinnable "starter kits" that are installed as part of the umbraco installation process.  Projects such as this one are installed as packages on an "empty" site.  The confusion is understandable.
    Dan
  • Tman 3 posts 23 karma points
    Jul 22, 2013 @ 14:18
    Tman
    Complete newbie with umbraco here ...I have installed the latest and greatest "Umbraco" v6.1.2.  I was then asked to choose from a selection of starter kits. I chose the simple kit (Simple starter kit - as advised by the text). Installed fine.. I then tried to install in the site admin  "Business website starter package",,,,however this fails every time I try to install. I keep getting the message,, "Sequence contains no elements". However I noticed the files seem to be there, under “installed packages”, but are not available in the content section of the admin tool. Could this be versioning or some kind of conflict ....?
  • Jonathan Hart 32 posts 51 karma points
    Nov 11, 2013 @ 19:15
    Jonathan Hart
    I too am getting this same error.  Thoughts?
