  • batmanflys 30 posts 41 karma points
    Sep 07, 2011 @ 23:02
    batmanflys
    Contact us form problem
    I have installed the starter kit and bar a few problems with the blog which I have resolved it is all working fine, however the contact form is throwing me a strange error message.
    Error creating control (usercontrols/RunwayContactForm/Contact.ascx).
    Maybe file doesn't exists or the usercontrol has a cache directive, which is not allowed! See the tracestack for more information!
    DEBUG gives this info
    Error creating usercontrol (usercontrols/RunwayContactForm/Contact.ascx)
    Could not load type 'UmbracoShop.Controls.Contact'.
      at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
    Any ideas?
  • Euan Rae 105 posts 135 karma points
    Sep 08, 2011 @ 11:45
    Euan Rae
    Can you post the trace info from the page?
    Sep 12, 2011 @ 03:32
    batmanflys
    Euan,
    How do i get the trace info, I have posted the debug above?
  • skiltz 501 posts 701 karma points
    Sep 12, 2011 @ 03:36
    skiltz
    What is the Assembly umbracoshop? Doesn't seem like a normal runway file.
  • chris cameron 36 posts 56 karma points
    Sep 12, 2011 @ 09:17
    chris cameron
    standard business website starter kit install
    Sep 12, 2011 @ 10:14
    Euan Rae
    to get trace info: put '?umbracodebugshowtrace=true' as part of the query string
    Sep 12, 2011 @ 10:35
    chris cameron
    I must be doing something stupid. /contact-us.aspx?umbracodebugshowtrace=true does not work, just reloads the page
    Sep 12, 2011 @ 10:37
    Euan Rae
    in the web.config, make sure the key 'umbracoDebugMode' is set to 'true'.  Putting in that query string parameter should then cause the trce info to be written out at the bottom of the page
    Sep 12, 2011 @ 10:45
    chris cameron
    Yep it is, still no debug coming up. When I ran this the other day at work i was shown the below in red
    Sep 12, 2011 @ 10:52
    dandrayne
    I should just note that this problem seems to be related to the starter kit offered during the install process, which isn't the same as this package (which has no contact form).
    Dan
    Sep 12, 2011 @ 11:02
    chris cameron
    only package installed is the business starter kit. Is it easier to perhaps install a contact form package and use this in my template?
    Sep 12, 2011 @ 11:11
    chris cameron
    got the trace working.
    here is the full error message
      at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
      at System.Web.UI.TemplateParser.ParseInternal()
      at System.Web.UI.TemplateParser.Parse()
      at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
      at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
      at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
      at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
      at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
      at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
      at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
      at System.Web.Compilation.BuildManager.GetVPathBuildResult(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean ensureIsUpToDate)
      at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
      at umbraco.macro.loadUserControl(String fileName, MacroModel model, Hashtable pageElements)
    Sep 12, 2011 @ 11:12
    chris cameron
    There is another error line as well
    macro No macro with alias '' found
  • Pagggy 28 posts 71 karma points
    Apr 04, 2012 @ 22:09
    Pagggy
    any update on this? i got same error.
