  • Vincent Ashby-Smith 67 posts 196 karma points
    May 14, 2014 @ 16:19
    Vincent Ashby-Smith
    Categories Sidenav issue
    Hi Luke, thanks for the recent update. Unfortunately i've got a small issue with the right hand side categories section. I've created some new categories and assigned some posts to these categories, but when i click on one of the categories i get the following error:
    Unfortunately, no results were found for '' in Blog, try searching a higher level.
    All the other side widgets work fine. It's probably something i've missed but if you could shed any light that would be great :)
  • Luke Alderton 192 posts 509 karma points
    May 15, 2014 @ 12:41
    Luke Alderton
    Hi Vincent,
    Sorry about that, I've had a look at the 'SmartListPosts.cshtml' file and created a fix. You can download it from here:
    http://s000.tinyupload.com/index.php?file_id=26861438408520789754
    Just replace the 'SmartListPosts.cshtml' file in your Partials folder, I'll also release an updated package with the fix in today.
    Thanks, Luke
