Error in Installation : Guid should contain 32 digits with 4 dashes
Upon installing Smart Blog v 2.0.9, I am getting following error:
Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Exception Details: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Exception Details: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx).
Source Error:
I do not see any new Content or Doc Type created. Nor do I see the Blog Management Tab in Content Dashboard.
I see Smart Blog under Installed Packages. But Uninstall button there doesnt work.
Please help.
Never Mind
I was using the wrong version of SmartBlog I guess.
Since it said that v1 was compatible till Umbraco 6.0.6, I tried installing SmartBlog v2 for Umbraco 6.2.1, wherein i faced this error.
However, then I tried installing SmartBlog v1 on Umbraco 6.2.1 and it worked.
