  • Thomas T 66 posts 227 karma points
    Feb 17, 2015 @ 15:29
    Thomas T
    Throws error in smart management console
    I just installed Smart Blog package for Umbraco version 7. When I open management console, it throws error as in the attachment.
    Feb 17, 2015 @ 15:33
    Hi Thomas and welcome to our :)
    What database did you install Umbraco on? If it's CE SQL or MySQL then it might be the issue. I'm not sure whether the package support CE SQL/MySQL or not.
    Feb 17, 2015 @ 15:52
    Dennis Aaen
    Hi Thomas and Jan,
    The package does not seems to support MySQL and SQLCE at the moment, try to see this post https://our.umbraco.org/projects/starter-kits/smart-blog/help/56638-Error-on-management-on-clean-install
    /Dennis
    Mar 05, 2015 @ 05:25
    Thomas T
    Hi Dennis,
              The package didn't support those databases as you said. So I migrated to MSSQL database.Now it is working fine .
              This post will help to overcome this,  https://our.umbraco.org/projects/starter-kits/smart-blog/help/61440-Does-SmartBlog-support-SQL-CE-database
