I have installed SmartBlog 2.1.0 on Umbraco v7.0.2
Whenever I go to the dashboard, I am not able to save any changes on the dashboard. No event seems to get fired on Click of Save Settings button or even Approved, Delete or Refresh comments buttons. I get confirmation popups asking if I am sure to Approve/Delete comments. But on click of Yes nothing happens.
No request is posted in the browser console too.
What could be going wrong?
But SmartBlog 2.0.9 on Umbraco v7.0.2 are working fine.
Smart Blog Management dashboard is not working
I think there is bug in SmartBlog 2.1.0.
what would be the fix??
Hi Sanjeev,
Have you checked the Smartblog.Config settings?
If you could provide more details on the configuration used, may be i can help
Also check this help>>
https://our.umbraco.org/projects/starter-kits/smart-blog/bugs-feature-requests/49649-Could-not-load-file-or-assembly-SmartLibraries
This might answer you
Swathi
