There is an issue with the paging where it doesn't retain the existing query string parameters (Category, Author, Tags)
Managed to do a work around with Javascript but it's not ideal.
I'm having the same issue, and also about to work around this using Javascript. Did you manage to find a better solution?
Paging Issue
