  • Yannick Smits 321 posts 718 karma points
    Mar 24, 2011 @ 14:11
    Yannick Smits
    strange url behavior
    I have a triple-lingual setup with different nodes on different url's.
    The URL's are:
    http://www.cease-therapy.com
    http://www.cease-therapie.nl
    http://romania.cease-therapy.com
    The sitemaps for the first 2 are generated correctly but for the third (romania) it fails, namely it's showing a url like:
    http://romania.cease-therapy.comhttp://romania.cease-therapy.com/programari/practicieni-acreditati
    The strange thing is that it only does this for second level nodes :S
    When i look into umbraco and lookup the node's "Link to document" property only for the url's that fail it shows up with http://romania.cease-therapy.com in front. All the other nodes that render correctly are in the relative format. Is this a bug in umbraco? Anyone else noticed this? Fix?
    Mar 24, 2011 @ 14:46
    Sebastiaan Janssen
    Sounds like you enabled useDomainPrefixes and didn't republish the complete site. The Razor version of the package handles this correctly now, the XSLT version not yet though.
    So the workaround is to republish al nodes plus all children and you should be good to go!
  • Bjarne Fyrstenborg 1286 posts 4060 karma points MVP 8x c-trib
    Feb 01, 2013 @ 18:53
    Bjarne Fyrstenborg
    I had a similar issue..
    I am using umbraco v 4.11.1 .. and use the package version 2.0.1 and use the xslt version.
    When I manage hostname and set e.g. www.mydomain.dk and access http://www.mydomain.dk/sitemap.aspx the loc node look like this:
    <loc>http://www.mydomain.dk/da/forside/</loc>;
    if I access http://mydomain.dk it look like this:
    <loc>http://vejstrup.dkhttp://www.mydomain.dk/da/forside/</loc>;
    and I got errors when testing the sitemap in Google webmastercentral.
    So I had to ensure that the link to sitemap in robot.txt is with www: Sitemap: http://www.mydomain.dk/sitemap.aspx and manage hostname is with www.
    First I had set it without www, but in Google had already prefixed the domain with www.mydomain.dk/ ... and I should enter sitemap.aspx
    Perhaps because the site was added as www.mydomain.dk
    /Bjarne
