  • Anthony Dang 1404 posts 2558 karma points MVP 3x c-trib
    Jun 24, 2011 @ 14:47
    Anthony Dang
    Razor version issue
    When umbracoNaviHide is set to true on a node (say a container) but you want the sitemap to display it's children, then the script will not get the children.
    This may not apply to everyone but this is what I did to the script:
    @ListChildNodes(Model.AncestorOrSelf(1))
    @helper ListChildNodes(dynamic startNode)
    Response.ContentType = "text/xml";
    const int maxLevelForSiteMap = 100;
    foreach (var node in startNode.Children)
    if (node.template > 0)
    if (node.umbracoNaviHide == false && node.HasAccess && !node.IsProtected)
  • Bojan 16 posts 131 karma points
    Dec 29, 2016 @ 16:09
    Bojan
    Hi Anthony,
    I needed this solution also so I've changed the code to support parent nodes (containers or classic pages) to work with umbracoNaviHide.
    @using Umbraco.Core.Models
    @using Umbraco.Web
        var startNode = Model.Content.AncestorOrSelf(1);
    @CreateXML(startNode)
    @ListChildNodes(startNode)
    @helper ListChildNodes(IPublishedContent startNode)
            if (node.TemplateId > 0)
                @CreateXML(node)
            if (node.Level <= maxLevelForSiteMap && node.Children.Any())
                @ListChildNodes(node)
    @helper CreateXML(IPublishedContent node)
        if (node.IsVisible() && Umbraco.MemberHasAccess(node.Path) && !Umbraco.IsProtected(node.Path))
            <url>
                <loc>@node.UrlAbsolute()</loc>
                <lastmod>@($"{node.UpdateDate:s}+00:00")</lastmod>
                    var frequency = node.GetPropertyValue<string>("SearchEngineSitemapChangeFreq");
                    var priority = node.GetPropertyValue<string>("SearchEngineSitemapPriority");
                @if (!string.IsNullOrEmpty(frequency))
                    <changefreq>@frequency</changefreq>
                @if (!string.IsNullOrEmpty(priority))
                    <priority>@priority</priority>
            </url>
    Bojan
