  • Michiel (NSC) 95 posts 115 karma points
    Oct 28, 2011 @ 15:51
    Michiel (NSC)
    Error parsing XSLT file: \xslt\CultivSearchEngineSitemap.xslt
    Just installed it and browsed to /cultivsearchenginesitemap.aspx
    Oct 28, 2011 @ 22:22
    Hi Michiel
    What version of Umbraco did you install it on? And have you tried adding ?umbdebugshowtrace=1 to the url to see if you get any error message in the trace stack that could point you in the right direction?
    Oct 31, 2011 @ 11:03
    Michiel (NSC)
    I installed it on the latest version, 4.7.1. I did the trace thing, but it didn't indicate any errors. I have since installed the Razor package, because XSLT is not really my thing (last time I had to use it was 2004...)
    Oct 31, 2011 @ 18:58
    Hmm, ok...could be that the .dll was not registered properly or the xslt was wrong or something like that. But good to hear you managed to move on with a language you prefer :)
    Nov 01, 2011 @ 10:38
    Michiel (NSC)
    Well, if the XSLT is wrong then nobody should be able to use this plugin right now. Maybe the author will comment on this.
