  • Frederik T 242 posts 373 karma points
    Jan 12, 2012 @ 10:57
    Frederik T
    Cultiv sitemap and url rewriting
    Hopefully this is a simple question:
    If i have a rule written in UrlRewriting.config which makes all url's remove .aspx extension, will that create complications with the sitemap? Because i have noticed that all the links generated by the cultiv sitemap xslt file has the .aspx exension.
    Jan 12, 2012 @ 11:10
    Dirk De Grave
    Frederik,
    Simply change the settings in web.config should solve that (and would no longer require urlrewriting rule)
    <add key="umbracoUseDirectoryUrls" value="true" />
    /Dirk
