  • Jamie Robb 10 posts 40 karma points
    Aug 06, 2012 @ 12:10
    Jamie Robb
    Is it possible to generate a physical sitemap.xml file?
    I'm currently using the latest razor version of the Cultiv Search Engine Sitemap without any bother.  However, I was wondering if there's anyway to generate an actual xml file of the sitemap instead of dynamically outputting the XML through the sitemap URL?
    Thanks.
