  • Trond K. 11 posts 52 karma points
    Jan 17, 2013 @ 14:43
    Trond K.
    V6 beta problem - no pages (with fix)
    I installed the (razor) package in v6 but got no pages in the sitemap (just the empty <urlset> tag.
    There seems to be some problem (bug?) with the Linq parsing of the Where clause for umbracoNaviHide.
    To get it working, I done this:
    Before:
     foreach (var node in startNode.Children
            .Where("HasAccess")
            .Where("!IsProtected")
            .Where("umbracoNaviHide == false")
            if(node.template > 0) {
                <url>
    After:
            .Where("HasAccess")
            if(node.template > 0 && !node.umbracoNaviHide) {
                <url>
    I also had to add the () to the Count method as described by Dan in this thread
    if (node.Level <= maxLevelForSiteMap && node.ChildrenAsList.Count() > 0)
    Hope this helps!
    -tk
  • Josh Olson 79 posts 207 karma points
    Feb 06, 2013 @ 15:14
    Josh Olson
    This worked for me too! Thanks!
    I tried just adding the () th the Count method also, but that did not sort the issue. It was not until I made the changes you suggested that things started working.  I will raise a glass to you this evening and drink to your health!
    (running 4.11.1, not v6 though)
    Josh
