I can't figure out whether its the structure of my site that causes the exception below. My site is multilingual with multiple nodes at level 1 plus som misc nodes for sitebar etc.. I'm running the latest razor edition of the package on Umbraco 6.1.4.
The exception is only triggered when trying to access the url of the template, when adding the template to a document type and creating a node in the content tree, everything works just fine. I would just prefor not having any such nodes in the content tree for the content editors to mess with ;)
I've got what looks to be the exact same issue and it gets triggered when I try to go to a page that doesn't exist. I would expect my site to go to a custom 404 page defined in umbracoSettings.config
I you want to get the Cultiv Search Engine Sitemap working and are getting the error, what I did was to create a sitemap node in the content tree and then assign it to a template that contains the macro. This way I was able to access the sitemap without the exception.
But maybe you are just looking for a way to create a custom 404 page for your site?
StartIndex cannot be less than zero.
[ArgumentOutOfRangeException: StartIndex cannot be less than zero. Parameter name: startIndex] System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy) +10698829 AutoFolders.NotFoundHandler.Execute(String url) +223 Umbraco.Web.Routing.ContentFinderByNotFoundHandlers.HandlePageNotFound(PublishedContentRequest docRequest) +1118 Umbraco.Web.Routing.ContentFinderByNotFoundHandlers.TryFindContent(PublishedContentRequest docRequest) +10 Umbraco.Web.Routing.PublishedContentRequestEngine.<FindPublishedContent>b__2a(IContentFinder finder) +15 System.Linq.Enumerable.Any(IEnumerable`1 source, Func`2 predicate) +146 Umbraco.Web.Routing.PublishedContentRequestEngine.FindPublishedContent() +215 Umbraco.Web.Routing.PublishedContentRequestEngine.FindPublishedContentAndTemplate() +195 Umbraco.Web.Routing.PublishedContentRequestEngine.PrepareRequest() +87 Umbraco.Web.UmbracoModule.ProcessRequest(HttpContextBase httpContext) +316 Umbraco.Web.UmbracoModule.<Init>b__7(Object sender, EventArgs e) +80 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +136 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +69I've got what looks to be the exact same issue and it gets triggered when I try to go to a page that doesn't exist. I would expect my site to go to a custom 404 page defined in umbracoSettings.config
Did you get anywhere with this?
