I'm on Umbraco 4.10.1
Installed the Cultive Search Engine Sitemap.
Trying to access: http://mydomain.com/cultivesearchenginesitemap or http://mydomain.com/cultivesearchenginesitemap.aspx - both results in a redit to my frontpage.
I can see, that other had similar problems, but could get the sitemap showing while writing their URL like this:
http://mydomain.com/home/cultivesearchenginesitemap but that don't work here either (This probably because we made some changed to UrlRewrite.config - see below)
I'm newbee to Umbraco, so I don't have that much experience goofing arround in this system yet :-)
Info that may be helpful:
My structure is like this:content-domain--da-DK--en-GB---Frontpage---Company1---Company2---Company3---etc etc--fo-FO--fi-FI-Banners small-Banners high-Galleries-Companies-Opening Hours-Trash
My /config/UrlRewriting.config looks like:
<add name="www-301-redirect" redirect="Domain" gnoreCase="true" rewriteUrlParameter="IncludeQueryStringForRewrite" virtualUrl="http://www.mydomain.com/(.*)" redirectMode="Permanent"destinationUrl="http://mydomain.com" /> <add name="handlers" virtualUrl="^~/data/(.*)$" rewriteUrlParameter="ExcludeFromClientQueryString" destinationUrl="~/en-GB/frontpage/?altTemplate=$1" ignoreCase="true" />
Anyone has a hint for what I can do, getting a XML sitemap?
/Bjarke
I tried to run the package with Umbraco v6.1.5 (Assembly version: 1.0.4993.19246).
When going to http://www.yourdomain.com/cultivsearchenginesitemap it gives a razor error.
This was because the following code:
if (node.Level <= maxLevelForSiteMap && node.ChildrenAsList.Count > 0)
had to be changed to
if (node.Level <= maxLevelForSiteMap && node.ChildrenAsList.Count() > 0)
Where did you change that? Wich file?
Package: Cultiv_Search_Engine_Sitemap_(Razor_edition)_1.0.2.zip
File: CultivSearchEngineSitemap.cshtml
I think i posted this in the wrong place - I don't believe it has anything to do with your problem. Sorry.
Don't think so either, because I don't find a such file via FTP, on our server :-)
Although if you want you can install the Razor version, and edit the code where I pointed out, then it might work for you :)
Sitemap don't show - redir to frontpage
content
-domain
--da-DK
--en-GB
---Frontpage
---Company1
---Company2
---Company3
---etc etc
--fo-FO
--fi-FI
-Banners small
-Banners high
-Galleries
-Companies
-Opening Hours
-Trash
/Bjarke
