After installing there appears to be no partial page created for the page to reference.
Version 7.1.4
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<urlset xmlns="http://www.sitemaps.org/schemas/sitemap/0.9" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sitemaps.org/schemas/sitemap/0.9 http://www.sitemaps.org/schemas/sitemap/0.9/sitemap.xsd">
Error loading MacroEngine script (file: CultivSearchEngineSitemap.cshtml)
</urlset>
Error loading CultivSearchEngineSitemap.cshtml
Version 7.1.4
Any ideas??
TIA
I just had the same problem.
Open the CultivSearchEngineSitemap.cshtml file. Line 30 is:
Change it to:
Awesome, you're a legend! Worked a treat.
This worked perfectly for me!
Comment author was deleted
Made a new topic instead.
Well spotted, Sarah
Perfect!! Thank you!
