  • Simon 692 posts 1068 karma points
    Jan 26, 2015 @ 12:46
    Simon
    Once installed and Changed the View Name
    I would like to know what is the last step after install the package and chnage the view to sitemap, in order for search engines to know with this sitemap xml.
    Regards.
    Jan 26, 2015 @ 12:56
    Hi Simon
    Are you thinking about how to let Google know about the sitemap? Then you should login to google webmaster tools and assign it to your website from the administration in there.
    Hope this helps.
    Jan 26, 2015 @ 12:58
    Dennis Aaen
    Hi Simon.
    If you can access the sitemap, and get the XML in the browser, then you just need to add the sitemap, into an robot.txt to tell google where to find your XML sitemap.
    Try to see this example:
    http://www.sitemaps.org/protocol.html#submit_robots
    Hope this helps,
    /Dennis
    Jan 26, 2015 @ 13:24
    Simon
    Hi Dennis,
    the site is still running locally.
    How can I reference to the sitemap in the robots.txt?
    Thank you
    Jan 26, 2015 @ 13:29
    Dennis Aaen
    Hi Simon
    Then you just can use the url where you can access it on your local machine, but when you set your site live, then you need to change it to the right url: e.g http://www.yourdomain.com/sitemap
    So if your template for the sitemap in Umbraco has the name: sitemap, then it would be:
    http://site.localhost/sitemap
    Hope this make sense if not the please ask again.
    /Dennis
