Cultiv Search Engine Sitemap doesn't add links from Articulate blog
Hi all,
I am using Cultiv Search Engine Sitemap package to build sitemap. Recently I added blog based on Articulate package, but blog pages are missed in the sitemap. How I can customize or extend sitemap plugin to fit my needs? Do I need to setup some extra properties in a blog document type?
Yes this is still the behvaiour but it is really easy to amend the plug-files to tell it to include them.
The plugin checks for certain things, such as having a template associated with a document type. Articulate purposely doesn't have a template for every document type due to how it works so you'll just need two roll your own bit of code for the Articulate nodes.
Hi all,
Best regards, Dmytro
I'm looking into adding this package to our site, but I'm using Articulate for two blogs on the site. Is this still an issue?
Hi S,
Nik
Thank you, Nik!
