  • Srinivasan 10 posts 80 karma points
    Oct 04, 2019 @ 13:32
    Srinivasan
    Cultiv Search Engine Sitemap
    I installed the Cultiv Search Engine. I added the
    Sitemap: http://localhost:62062/sitemap.aspx
    link in robots.txt Its generated template and macro.but no document type.
    I dont know what i do the next step?
    sitemap.cshtml(template)
            Layout = null;
            Response.ContentType = "text/xml";
        <urlset xmlns="http://www.sitemaps.org/schemas/sitemap/0.9" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.sitemaps.org/schemas/sitemap/0.9 http://www.sitemaps.org/schemas/sitemap/0.9/sitemap.xsd">
            @Umbraco.RenderMacro("Sitemap")
        </urlset>
    sitemap.cshtml (macro)
    @using Umbraco.Core.Models
    @using Umbraco.Web
    @ListChildNodes(Model.Content.AncestorOrSelf(1))
    @helper ListChildNodes(IPublishedContent startNode)
        const int maxLevelForSiteMap = 100;
        foreach (var node in startNode.Children.Where(x => Umbraco.MemberHasAccess(x.Id, x.Path)).Where(x => !Umbraco.IsProtected(x.Id, x.Path)).Where(x => x.IsVisible()))
            if (node.TemplateId > 0)
                <url>
                    <loc>@node.UrlWithDomain()</loc>
                    <lastmod>@(string.Format("{0:s}+00:00", node.UpdateDate))</lastmod>
                        var freq = node.GetPropertyValue<string>("SearchEngineSitemapChangeFreq");
                        var pri = node.GetPropertyValue<string>("SearchEngineSitemapPriority");
                    @if (!string.IsNullOrEmpty(freq))
                        <changefreq>@freq</changefreq>
                    @if (!string.IsNullOrEmpty(pri))
                        <priority>@pri</priority>
                </url>
            if (node.Level <= maxLevelForSiteMap && node.Children.Any())
                @ListChildNodes(node)
