  • Donald St. Martin 83 posts 128 karma points
    Aug 27, 2010 @ 21:54
    Donald St. Martin
    Problems when using 4.5.x
    Do you have any plans on updating this project to run on v4.5.x and .NET 4?
    This is a great package and I would love to continue using it!  Currently, I am getting a 404 error with:
    Requested URL: /umbraco/~/umbraco/plugins/FergusonMoriyama/feedcache/Config.aspx
    Donald
  • Darren Ferguson 1022 posts 3259 karma points MVP c-trib
    Aug 28, 2010 @ 11:01
    Darren Ferguson
    It will be updated, but it isn't a priority as I don't have any clients currently using it.
  • Michael Worrall 57 posts 82 karma points
    Nov 11, 2010 @ 13:25
    Michael Worrall
    Agreed this package is great, have you had chance to update it for v4.5?
    Mike
  • Stephen Kiers 41 posts 62 karma points
    Nov 30, 2010 @ 03:28
    Stephen Kiers
    I 3rd it...
  • Micah Smith 2 posts 22 karma points
    Dec 03, 2010 @ 16:30
    Micah Smith
    I'd love to see it updated also.
  • Kenneth Solberg 227 posts 418 karma points
    Dec 06, 2010 @ 22:51
    Kenneth Solberg
    Any news on 4.5 support? :-)
    Dec 07, 2010 @ 19:40
    Darren Ferguson
    Ok, so it is updated for version 4.5 - please vote it up.
    Thanks.
    Dec 07, 2010 @ 19:43
    Darren Ferguson
    BTW - I've removed the config GUI. the feeds need to be configured manually in ~/config/feedcache2.config
    Thanks.
    Dec 07, 2010 @ 22:12
    Kenneth Solberg
    Thanks Darren!
    Dec 08, 2010 @ 18:08
    Donald St. Martin
    Not sure if anyone else is getting this error but I did get: Could not load type 'FergusonMoriyama.Umbraco.FeedCache.PostInstall'.
    Edit: This only seemed to happen when previous Feed Cache versions were installed.
    It looks like everything installed correctly though.
    Donald
  • All Blonde 86 posts 138 karma points
    Jun 13, 2013 @ 18:20
    All Blonde
    I can tell you that it does not work with Umbraco 6.0+
    Had to build my own macro to replace this package...
