  • Amalie Wowern 145 posts 274 karma points MVP c-trib
    Sep 05, 2016 @ 06:27
    Amalie Wowern
    Wrong redirect when using https
    When a member goes directly to a file the member doesnt have acces to i get redirected wrong
    This is the url https://Website.dk/www.website.dk/login/du-har-ikke-adgang?returnurl=%2fmedia%2f1872%file.docx
    Umbraco 7.4
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Sep 05, 2016 @ 06:34
    Richard Soeteman
    That is strange since it should redirect to the niceurl (relative page) What is the result when you do niceurl on the loginpage id?
    Sep 05, 2016 @ 07:33
    Amalie Wowern
    Its the normal url https://website.dk/login
    Sep 05, 2016 @ 07:36
    Richard Soeteman
    Mediaprotect expects a relative url.. I'll make a fix for you later.
    Sep 05, 2016 @ 07:39
    Amalie Wowern
    Thank you :-)
    Sep 05, 2016 @ 07:51
    Richard Soeteman
    Should be fixed with the version below. Also your ordering issue.
    https://www.dropbox.com/s/vj2a8h5ukwr7317/mediaprotect17.zip?dl=0
    Sep 05, 2016 @ 08:05
    Amalie Wowern
    Thanks for the super fast solution:-)
  • Arun 144 posts 407 karma points
    Dec 31, 2019 @ 04:53
    Arun
    This issue exists for me., and the given link by Richard is 404. When i gave a URL without https then that is opening as a page within the current website. Whats the solution
    Im using the code
    var relatedLink = item.Value("relatedLink");
    Jan 06, 2020 @ 08:16
    Richard Soeteman
    Is this a Mediaprotect or general issue you are having?
    Best,
    Richard
