  • Mads Justesen 11 posts 121 karma points
    Jan 20, 2023 @ 11:30
    Mads Justesen
    Using MediaProtect with a Eternal Login
    Hej there!
    I'm currently working on a website for a client who would like to protect some of their media files behind a login and MediaProtect seems like a perfect solution for this, however, I do have a question as our solution utilizes a external login.
    Is it posible to hook up MediaProtect to the external login or would I have to create a "shadowMember" which the users connect to when they log in with the external system?
    Currently scratching my head trying to figure out the best solution, so I'm hoping that someone else might have been in the same situation and got some suggestions.
    Kind regards
    Mads
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Jan 20, 2023 @ 13:54
    Richard Soeteman
    Hi Mads,
    Is possible a shadowmember is easiest but you can implement your own
    MediaProtect.Common.Providers.AuthenticationIAuthenticationProvider
    Make sure Alias is unique and register that in a custom composer
    builder.Services.AddUnique<IAuthenticationProvider, yourAuthenticationProvider>();
    Then it should pick up your custom provider. Make sure to add the roles to the returned user, that is what get's matched during check of the file.
    Hope this helps,
    Richard
