  • Ryan 35 posts 129 karma points
    May 12, 2014 @ 22:36
    Ryan
    SQL 2012/IIS 8?
    Will this work with SQL Server 2012 and IIS 8?  I'm not sure the age of the documentation.  Thanks for your help.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    May 13, 2014 @ 06:55
    Richard Soeteman
    Hi Ryan,
    Yes this will work with SQL Server 2012 and IIS8. I need to update the documentation indeed.
    Best,
    Richard
    May 13, 2014 @ 14:18
    Ryan
    Thank you for the quick reply!
