  • Bo Jacobsen 610 posts 2409 karma points
    Oct 06, 2016 @ 13:47
    Bo Jacobsen
    Media Protect Return Url Issue
    Hello.
    Using Media Protect 1.5.1.0
    Is there a way to overrule the returnUrl when you log in? What i want is to return to another url when i log in. And still be able to use the returnUrl after that.
    When i try to download a file at https://www.website.com/media/package.zip i get redirected to https://www.website.com/login/?returnurl=%2fmedia%2f214%2fpackage.zip and thats what is should do.
    But when i return Redirect("/member/?returnurl=%2fmedia%2f214%2fpackage.zip") in my login SurfaceController, it starts to download the file and stay on https://www.website.com/login/?returnurl=%2fmedia%2f214%2fpackage.zip.
    Now if i manuelly type in /member/?returnurl=%2fmedia%2f214%2fpackage.zip, it removes the returnurl and download the file as it should.
    Any idear?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Oct 06, 2016 @ 14:03
    Richard Soeteman
    Hi Bo,
    Not sure why it would not redirect to the page you specified. This was the old url passing method of aspx controls.
    Oct 07, 2016 @ 09:58
    Bo Jacobsen
    From what version is that behavior updatet?
    Oct 08, 2016 @ 06:40
    Richard Soeteman
    Since Umbraco changed from webforms to MVC it has changed.
    Oct 10, 2016 @ 08:33
    Bo Jacobsen
    Now i downloaded the newest version of media protect 1.6.2. To try and see if there was a different.
    What i notice now is that if i type in /member/?returnurl=/somefile/ it goes to login page everytime. Even if the member is logged in.
    Is there a way to override this behavior?
    It does however download the file as it should ;)
    Oct 10, 2016 @ 08:48
    Bo Jacobsen
    I solved it with a hax.
    When there is a returnurl querystring in the url. I removed it and saved it in a session. Then when i land on another site. I set a timeout jquery script to reload the current page with a new returnurl querystring and remove the current session.
    Then it stays on the page i want, and download the file.
    Oct 10, 2016 @ 08:41
    Richard Soeteman
    Hi Bo,
    If you change the name of returnurl to redirecturl or something that should help. It's because this property was based on the asp:login control that was used in webforms and that would handle returnurl out of the box.
    Best,
    Richard
