  • blackhawk 313 posts 1368 karma points
    Sep 20, 2017 @ 20:35
    blackhawk
    Using Library properties
    I'm currently running Umbraco 7.6.6
    After installing Media Protect into my instance, I gave role based permissions onto one of my images, within my Media Section.
    I'm looking into the Media Protect Documentation and want to use the Library helpers to confirm that my image is protected.
    I placed the following helper code on my master template
     @*check to see if the current media item is protected*@
     <p>@Umbraco.MediaIsProtected(1136)</p>
    But it generates the following error...
     2017-09-20 16:32:27,508 [P15784/D2/T129] ERROR Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred
    System.Web.HttpCompileException (0x80004005): c:\Users\um\documents\m\_projects\cms\umbraco\umb05\umb05\Views\ContentPage.cshtml(30): error CS1061: 'Umbraco.Web.UmbracoHelper' does not contain a definition for 'MediaIsProtected' and no extension method 'MediaIsProtected' accepting a first argument of type 'Umbraco.Web.UmbracoHelper' could be found (are you missing a using directive or an assembly reference?)
       at System.Web.Compilation.AssemblyBuilder.Compile()
       at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
       at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
       at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
       at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
       at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean throwIfNotFound)
       at System.Web.Compilation.BuildManager.GetCompiledType(VirtualPath virtualPath)
       at System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer)
       at Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer)
       at System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context)
       at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult)
       at System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult)
       at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult)
       at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
       at System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState)
       at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult)
       at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult)
       at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
       at System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState)
       at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
       at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
       at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
    What am I doing wrong?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Sep 21, 2017 @ 05:30
    Richard Soeteman
    Make sure you have a using statement for MediaProtect.Library.TypeExtensions in your view.
    Hope this helps,
    Richard
    Sep 21, 2017 @ 14:47
    blackhawk
    Adding the following to my view worked
    @using MediaProtect.Library.TypeExtensions;
    Thanks!
