Set Title and Description programatically when importing
Hi :)
Currently having an project where i have to import ALOT of old nodes from an old Umbraco 6 site - Is it possible to set title and description programatically?
With SEOChecker you can define default properties. When no title or descriioon is filled in those properties will be used. Is that something you can use?
Hi :)
Hi Anders,
Best,
Richard
I was hoping we could set them because the fields are filled - But i will try and see how can set the default values :)
You can also use the mapping option in datatypes. Both methods are explained in the manual.
Hope this helps,
Richard
