  • Sven 34 posts 138 karma points
    Aug 05, 2021 @ 10:23
    Sven
    SeoChecker Exceptions
    Hi Richard,
    We're getting some exceptions on our live cloud environment. Any idea how to fix these? We're getting these errors when we're publishing/creating any new pages.
    Versions: Umbraco 8.14.1 Deploy 4.1.2 Forms 8.7.5 SEOChecker 2.10.1
    System.Data.SqlClient.SqlException (0x80131904): String or binary data
    would be truncated in table '3stpwbm2kl5.dbo.SEOChecker_ConfigurationIssues', column 'ErrorDescription'. Truncated value: 'The robots.txt file contains:<br/><br/>
    User-agent: *<br/>
    Disallow: /<br/><br/>
    And doesn''t conta'.
    The statement has been terminated.
       at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
       at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
       at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
       at NPoco.Database.ExecuteNonQueryHelper(DbCommand cmd)
       at NPoco.Database.Execute(String sql, CommandType commandType, Object[] args)
       at SEOChecker.Core.Repository.ConfigurationIssues.ConfigurationIssuesRepository.(ConfigurationValidationError )
       at SEOChecker.Core.Repository.ConfigurationIssues.ConfigurationIssuesRepository.Save(List`1 result)
    ClientConnectionId:6dee149a-6244-4423-9b0c-59dc9e32c184
    Error Number:2628,State:1,Class:16
    Error number 2:
       at SEOChecker.Core.Umbraco.DocumentWrappers.UmbracoDocumentBase..(DocumentProperty )
       at System.Linq.Enumerable.WhereListIterator`1.MoveNext()
       at System.Linq.Enumerable.Count[TSource](IEnumerable`1 source)
       at SEOChecker.Core.Umbraco.DocumentWrappers.UmbracoDocumentBase.GetPropertyValue[T](String propertyAlias, Boolean recursive, String culture, String segment)
       at SEOChecker.Core.Umbraco.DocumentWrappers.UmbracoDocument..ctor(IContent doc, IContextInfo info, String culture, String segment)
       at SEOChecker.Core.Helpers.UmbracoDocumentHelper.GetFirstPublishedChildNode(IContextInfo contextInfo, String culture, String segment)
       at SEOChecker.Validators.ConfigurationValidators.TrailingSlashValidator.a4jtdxsbngyptnqmwcxshq8hfkwl5ufr    (List`1 , IContextInfo )
       at SEOChecker.Core.Validation.ConfigurationValidators.ConfigurationValidator.Validate()
    Thanks in advance!
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Aug 09, 2021 @ 10:05
    Richard Soeteman
    Hi Sven,
    Error 2 is fixed in the latest release. Error 1 is because of the length of an error description. I will make sure that is fixed in a next release but the error is because you are blocking goolgebot in robots.txt. you might want to change that anyway.
    You can modiffy the error message in the language file as well it's the reportIssueRobotsTxtBlockGoogleRequestDescription key.
    Best,
    Richard
    Aug 09, 2021 @ 12:02
    Sven
    Hey Richard, Thanks for responding.
    I've checked our robots.txt file and it seems like we are not blocking googlebot?
    Aug 09, 2021 @ 12:12
    Richard Soeteman
    Weird since that's the error you might want to update the sitemap entry as well ;-)
    Aug 09, 2021 @ 12:56
    Sven
    We're having a new error after upgrading the package to the latest version: Any idea what this could be?
       at SEOChecker.Core.Repository.Umbraco.UmbracoDocumentRepository.Single(Int32 id, IContextInfo context, String culture, String segment)
       at SEOChecker.Core.Validation.DocumentValidator.Validate(Int32 documentId, IContextInfo context, String culture, Boolean validateKeyWords, String focusKeyword, Boolean editMode)
       at SEOChecker.Core.Helpers.ValidationHelper.ValidatePreviewPage(Int32 documentId, String culture, Boolean editMode, Boolean validateKeyWords, String validationKeyword)
       at SEOChecker.DataTypes.Controllers.SEOCheckerApiController.Validate(SEOCheckerValidationModel model)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
       at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
       at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
    Aug 09, 2021 @ 13:19
    Richard Soeteman
    There is no change in the model, maybe client dependency update failed? Anything in chorm log?
