Following on from this thread: https://our.umbraco.com/packages/website-utilities/seo-checker/using-seochecker/106271-xml-sitemap-in-seochecker#comment-331343
I was just wondering on how to implement the URL correctly for Umbraco v10?
Our project does not have a web.config and is using JSON configs instead.
I did try a few options but no luck 😊
Thank you!
In .Net9+ you can define it in appsettings.json.
Append the following section after the Umbraco section as the manual describes:
, "SEOCheckerAppSettings": { "UmbracoApplicationUrl": "https://www.mysite.com" }
Hope this helps,
Richard
Apologies I must have missed that manual 😊
Thanks, Richard, I will give it a go!
Setting SEOChecker.UmbracoApplicationUrl in v10
Thank you!
Hope this helps,
Richard
