  • Harry Palmer 1 post 21 karma points
    Dec 05, 2023 @ 11:22
    Harry Palmer
    Disappearing fields after publishing
    Hi all, wanted to run this question here as I couldn't find any questions / resources about it.
    I've been running into an issue with SEO Checker where if I implement it into a new template that I've created. It shows the fields on creation and allows me to enter data within those fields, as seen in the image below:
    However on publishing it comes up as enter image description here
    I'm not too sure where else to go on this, so any suggestions would be much appreciated !!
    Thank you for your time
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Dec 05, 2023 @ 11:53
    Richard Soeteman
    You mention template? Did you also try with a normal document and did you do any configuration for the document type in SEOChecker document settings?
    Best,
    Richard
