  • Berit 9 posts 26 karma points
    Jul 01, 2014 @ 10:38
    Berit
    Redirects doesn't work in SEO Checker
    I can't seem to make the module in SEO Checker that fix links automatically work.
    The redirects I make in the Redirect Manager doesn't work - no inbound link errors is shown, nor does it change extensions from .php to .aspx.
    I have checked all the Redirect settings and the URL Rewriting in the Configuration.
    Any idea what I'm doing wrong?
    I'm using SEO Checker V1.5.2 on Umbraco 6.1.6
    Regards
    Berit
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jul 01, 2014 @ 10:46
    Richard Soeteman
    Hi Berit,
    Make sure you are using IIS7/8 in Integrated mode and make sure the following modules are configured in the System.Webserver/modules section in the web.config file.
      <remove name="SEOCheckerValidationqueueModule" />
      <add name="SEOCheckerValidationqueueModule" type="SEOChecker.HttpModules.ValidationqueueModule, SEOChecker" />
      <remove name="SEOCheckerUrlModule" />
      <add name="SEOCheckerUrlModule" type="SEOChecker.HttpModules.UrlModule, SEOChecker" />
    Hope this helps,
    Richard
    Jul 01, 2014 @ 11:14
    Berit
    Hi Richard
    That did it!! :-)
    Thank you
    Berit
