  • Heiko Luxenhofer 38 posts 138 karma points
    Jan 26, 2015 @ 11:09
    Heiko Luxenhofer
    404 setting not working with Umbraco 7.2.1
    Hallo,
    are there known issues with Umbraco 7.2.1 and SEOChecker 1.8.1 with 404 setting?
    We set PageNotFound-Setting with SEOChecker and it worked until we updated no newest Umbraco version. It only shows standard page not found screen. enter image description here
    Jan 26, 2015 @ 11:37
    Hi Heiko
    Is the node that is supposed to be shown still picked in SEO checker?
    Jan 26, 2015 @ 11:46
    Heiko Luxenhofer
    Yes, it is still picked.
    Jan 26, 2015 @ 11:48
    Hi Heiko
    Ok, perhaps you just need to go to the "CONTENT" node, right click it and choose "Republish entire site" in order to update the XML cache. Not sure it works but worth a try.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jan 26, 2015 @ 11:54
    Richard Soeteman
    Hi Just tested here and all works fine. I've tested on a single domain site using the picker on domain settings. You did the same and logging of 404 is working?
    Best,
    Richard
    Heiko Luxenhofer
    Hi Jan,
    just did it but nothing changed. Any other ideas?
    Heiko
    Jan 26, 2015 @ 12:08
    Heiko Luxenhofer
    Hi Richard,
    we have multiple domains in this Umbraco instance. Do you mean IIS logs?
    Heiko
    Jan 26, 2015 @ 13:48
    Richard Soeteman
    Hi Heiko,
    No logging of 404 errors in the Inbound link issues overview.
    Richard
    Jan 27, 2015 @ 14:59
    Heiko Luxenhofer
    Hi Richard,
    404 errors are logged in the inbound link issues overview. What could it be?
    Heiko
    Jan 27, 2015 @ 16:34
    Richard Soeteman
    Then the handler is running. Can you send the /umbraco/plugins/seochecker/config/seochecker.config file to support@soetemansoftware.nl
    Richard
    Jan 28, 2015 @ 09:22
    Heiko Luxenhofer
    Richard helped me to find the issue. I was sure fo using version 1.8.1 of SEOChecker, but it was installed version 1.8. Just updated package and it`s working now!
    Thanks to Richard for his help.
