  • Manasa 80 posts 201 karma points
    Jun 23, 2015 @ 11:10
    Manasa
    SEO Checker
    I am using SEO Checker for sitemap.xml. Is there a way where I can customize the xml file?If yes, how can I do it?
    Thanks.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jun 23, 2015 @ 11:34
    Richard Soeteman
    No sorry, if you need it customized you better create the functionality yourself. Only priority and refresh can be set,
    Best regards,
    Richard Soeteman Soeteman Software
    Quality Umbraco packages | http://www.soetemansoftware.nl
    Jun 23, 2015 @ 12:39
    Manasa
    Thanks Soeteman :)
  • Marija Cholakova 8 posts 78 karma points notactivated
    Aug 06, 2024 @ 13:47
    Marija Cholakova
    Hello Richard,
    How can I add the priority and change frequency tags to the sitemap.xml file? Only the loc and lastmod tags are displayed on the sitemap file generated by using the SEO Checker.
    Best Regards, Marija
  • Markus Johansson 1945 posts 5899 karma points MVP 2x c-trib
    Jun 23, 2015 @ 13:38
    Markus Johansson
    @Richard - would be nice to be able to extend this - ie. adding custom content. Like in my example with the yada.aspx=id=12893 senario. These pages would be good to have in the sitemap as well.
    Taking it one step further - it would be nice to have SEO Checker validate these pages as well.
    Jun 23, 2015 @ 15:54
    Richard Soeteman
    There is always v2 :)
