  • Markus Johansson 1945 posts 5898 karma points MVP 2x c-trib
    Jun 23, 2015 @ 11:54
    Markus Johansson
    Setting title using code
    Hi!
    I'm on version 1.8.1 of SEO Checker and I have pages where the content differese depending on a questiostring value (yada.aspx?id=5454).
    Is there a way for me to set the title for the current page so that SEO Checker will render it using this code?
    @Html.Raw(SEOChecker.Library.MetaData.Current.RenderTags())
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jun 23, 2015 @ 15:52
    Richard Soeteman
    Hi Markus,
    it will always use the default values that way. also if you use a querystring for different content you could end up having duplicate content issue.
    Best,
    Richard
    Jun 23, 2015 @ 18:51
    Markus Johansson
    Hi!
    Okey so there is no way to change what SEO Checker sends back as title? This is articles like
    /articles.aspx?id=123 /articles.aspx?id=3455
    With different content, titles and so. It's a legacy solution that stores stuff in custom tables - I know it would be best to move it but thats not an option atm.
    // m
    Jun 24, 2015 @ 05:40
    Richard Soeteman
    No, but you can do it yourself but why don't you redirect to a new page instead? In redirecty settings specify the based on querystring option and you can redirect to a new page with a real url instead.
