  • Marc Love (uSkinned.net) 447 posts 1790 karma points
    Jun 14, 2017 @ 11:45
    Sitemap.xml not created
    Hi Richard,
    I have just installed your updated version of SEO Checker on www.ministryofsound.com
    It isnt creating the sitemap.xml file.
    Any ideas what may be wrong?
    Marc
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Jun 15, 2017 @ 06:34
    Richard Soeteman
    Hi Marc,
    I think the handlers for Robots.txt and xmslsitemap are not configured in web.config. see usermanual how to fix that.
    Best,
    Richard
    Jun 16, 2017 @ 12:52
    Hi Richard,
    Still no luck. Following is in web.config:
    Anything else I can check?
    Marc
    Jun 16, 2017 @ 12:53
    Jun 16, 2017 @ 13:01
    Richard Soeteman
    I think a timeout is causing the issue, make sure to exclude document types that don't need to be in the sitemap. And increase timeout.
    Hope this helps,
    Richard
    Jun 19, 2017 @ 15:24
    Hi Richard,
    Thanks, that solved the issue. With regards to the way the sitemap.xml is generated. The document types for blog articles should be included however when I check the sitemap.xml file they arent there.
    An example post is:
    http://www.ministryofsound.com/posts/articles/2017/june/the-hydra-24-hours-of-london/
    Why would this not be getting added to the sitemap.xml file?
    Marc
    Jun 20, 2017 @ 06:49
    Richard Soeteman
    Could be taht you excluded the document type or that you set umbraconavihide and have the configuration setting exclude umbraconavihide enabled.
    Best to check the documentation how to configure this.
    Best,
    Richard
    Jun 20, 2017 @ 12:30
    Hi Richard,
    The Blog document types are not excluded and umbraconavihide isnt enabled. The Blog posts are located below nodes which arent included. Could this be the issue:
    Blog Landing (included) > Posts (excluded) > Year (excluded) > Month (excluded) > Blog Post (included)
    Marc
