Hi, i'm using ContentService to create umbraco content from c#. How can i set the SeoCheker property using Icontent.SetValue property?
You can use
SEOChecker.Core.DataTypeValues.SEOCheckerValues()
Then use the ToXmlString() method to serialize the values.
It's unsupported but should work.
Best,
Richard
How to Set SeoChecker metadata using ContentService
You can use
Best,
Richard
