  • Gregory 38 posts 128 karma points
    Dec 13, 2018 @ 14:24
    Gregory
    SEOChecker: SEOChecker: Error in PageNotFound Module
    Our Error log is filling up everyday with those errors:
        Message:
    Exception:
    System.Data.SqlClient.SqlException (0x80131904): String or binary data would be truncated.
    The statement has been terminated.
       at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
       at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
       at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
       at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
       at System.Data.SqlClient.SqlDataReader.get_MetaData()
       at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
       at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
       at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
       at System.Data.SqlClient.SqlCommand.ExecuteScalar()
       at StackExchange.Profiling.Data.ProfiledDbCommand.ExecuteScalar()
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.<>c__DisplayClass11_0.<ExecuteScalarWithRetry>b__0()
       at Umbraco.Core.Persistence.FaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command, RetryPolicy cmdRetryPolicy, RetryPolicy conRetryPolicy)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command, RetryPolicy retryPolicy)
       at Umbraco.Core.Persistence.PetaPocoCommandExtensions.ExecuteScalarWithRetry(IDbCommand command)
       at Umbraco.Core.Persistence.Database.Insert(String tableName, String primaryKeyName, Boolean autoIncrement, Object poco)
       at Umbraco.Core.Persistence.Database.Save(String tableName, String primaryKeyName, Object poco)
       at Umbraco.Core.Persistence.Database.Save(Object poco)
       at SEOChecker.Core.Repository.PageNotFound.PageNotFoundRepository.Insert(Uri uri, Uri referer, Int32 documentId, String redirect, Boolean isNotFound, ContentTypeEnum contentType, Boolean storeDomain, Boolean wildCard, Boolean storeQueryString)
       at SEOChecker.Core.Repository.PageNotFound.PageNotFoundRepository.Insert(Uri uri, Uri referer, ContentTypeEnum contentType)
       at SEOChecker.HttpModules.UrlModule.(Object , EventArgs )
    ClientConnectionId:2a3deb9d-7adb-4421-82b4-396db3836ad1
    Error Number:8152,State:13,Class:16
    I have been searching the forums and have not yet been able to find any solution to it. It tends to come with another message (exact same time stamp) (although the error code in bracket differ from one error to another):
    Message:
    Exception (41b477f7).
    Exception:
    ClientConnectionId:f4088c25-faf5-4841-bcf5-249fa1067f74
    Has anyone ever fixed this issue?
    We are using Umbraco Cloud 7.12.4 - with the issue only ever occuring on the live environments (SEOChecker is installed on all environments)
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Dec 13, 2018 @ 14:35
    Richard Soeteman
    Think the url column is to small in SEOCheckerPageNotFound table, can you increase the column?
    Dec 13, 2018 @ 16:43
    Gregory
    The Column is set to nvarchar(255) right now.
    Why would anything be bigger than that though?... and seen as this is only occurring on the live environment (all structure and content are identical on all environments) is there any reason for this?
    Is there any way to find out what it is trying to save here?
    I don't have any long file names (either in nodes, content or media) and no special characters as far as I can see...
    Dec 14, 2018 @ 08:26
    Richard Soeteman
    Best to increase to see what data is coming in. What happens is that bots try various urls and that only happens on a live site. That request will 404 and an entry will be created normally, only not in this case.
    If you increase and see a vary long invalid url please let me know or update the botfilter file https://github.com/rsoeteman/seochecker-resources/tree/master/BotFilter so these requests will be ignored.
    Best,
    Richard
