  • Bradley Kronson 63 posts 114 karma points
    Feb 26, 2019 @ 12:14
    Bradley Kronson
    HTTP site hosted behind HTTPS proxy not using correct protocol when generating sitemap
    So I have an interesting set up which is affecting the XML site map generation
    Our web site is hosted behind a proxy server which holds the sites SSL certificate.
    So the site sits native in HTTP, but the outside world sees it as HTTPS because of the proxy.
    When the sitemap is generated, it looks like the because the site is in HTTP, all links in the sitemap are generated by the IIS domain inside the proxy, ie the HTTP.
    This obviously causes some issues because all the links are actually HTTPS in the outside world
    Is there anyway to force the sitemap generation to use a specific domain ?
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Feb 26, 2019 @ 13:18
    Richard Soeteman
    It takes the scheme of the request that comes in so that makes sense. There was always a way to override this on node level but now I have made a config option that you can use to force HTTPS rendering. Add the following snippet to the appsettings of Web.config and all rendering of the sitemap should be https:
    <add key="SEOChecker.ForceHttps" value="true" />
    Download 2.2.4 Hotfix here. Will be included in the 2.2.4 release.
    Domain can be set when you assign the canonical domain to a rootnode
    Best,
    Richard
    Feb 26, 2019 @ 13:36
    Bradley Kronson
    Thanks Richard, much appreciated!
    May 31, 2019 @ 10:39
    Bradley Kronson
    Hi Richard, see you updated to 2.8, does that mean the 2.2.4 (for Umbraco 7) is not coming now?
    Jun 03, 2019 @ 07:06
    Richard Soeteman
    2.2.4 will also be release. 2.8 is Umbraco V8+ only. Can't support both Umbraco versions in a single package. Will do some final testing on 2.2.4 before release in the coming week(s)
    Jun 10, 2019 @ 14:04
    Bradley Kronson
    Thanks Richard, looking forward to it
  • Thomas 319 posts 606 karma points c-trib
    Mar 02, 2021 @ 13:53
    Thomas
    Hi Richard
    I have some issue with a site behind a HTTPS proxy.
    Running Umbraco 7.15.6 and seochecker 2.2.5.
    The 404 are not working it just gives the default umbraco 404 page
    Sitemap give a 504 Gateway Time-out - The server didn't respond in time.
    I have tried to add didn't do anything..
    Mar 03, 2021 @ 12:50
    Richard Soeteman
    SEOChecker takes the scheme from the HTTPRequest which is propably http instead of https. In V8 version I am about to release this is addressed but heavily using on Umbraco V8 architecture so not easy to backport to V7. If you can make sure scheme is always https it will work.
    Hope this helps,
    Richard
    Mar 03, 2021 @ 12:57
    Thomas
    Hey Thanks :)
    Not quite sure about what you mean here "If you can make sure scheme is always https it will work."
    The solution is set to umbracoUseSSL = false ?
    Mar 03, 2021 @ 12:59
    Richard Soeteman
    No mean that behind the proxy all requests need to be https as well.
    Mar 03, 2021 @ 13:34
    Thomas
    Hmm okay. It's not possible. All the certificates are handled by the haproxy infront of the load balancer
    Mar 04, 2021 @ 11:02
    Thomas
    Is there a way to force it to use https ?
    I have added ?
    Mar 04, 2021 @ 11:05
    Richard Soeteman
    For V8 that will be possible soon indeed as mentioned above yesterday.
