  • Dan Evans 631 posts 1018 karma points
    Sep 02, 2019 @ 13:27
    Dan Evans
    Hrefland tags
    How do I use SEO Checker to add hreflang tags to my variants?
  • Richard Soeteman 4054 posts 12927 karma points MVP 3x
    Sep 02, 2019 @ 15:46
    Richard Soeteman
    Hi Dan,
    In V8 this is done automatically based on language variants, in V7 or other implementations there is no standard so you need to set them yourself.
    Hope this helps,
    Richard
    Sep 02, 2019 @ 16:03
    Dan Evans
    Thanks, we are using V8 but not the meta-tagging function. Is there a way just to display hreflang tags in a template and no other SEO checker code?
    Sep 03, 2019 @ 05:01
    Richard Soeteman
    Hi Dan,
    It will render the other tags as well, not sure why you have disabled that since it will give you default properties out of the box as well.
    But you can just loop over the languages in that case and render the url for each other language to generate the correct hreflang urls.
    Best,
    Richard
