  • Bo Jacobsen 610 posts 2409 karma points
    Oct 03, 2019 @ 08:06
    Bo Jacobsen
    SEOChecker: Error running scheduled task
    Hi.
    I've had similar errors before in earlier versions of SeoChecker and Umbraco, but now it seems like it has comming back in Umbraco Cloud 8.1.5 and SeoChecker 2.8.2
    Do i maybe miss something in the web.config?
    Message:
    SEOChecker: SEOChecker: Error running scheduled task
    Exception:
       at System.Web.Hosting.IIS7WorkerRequest.GetQueryStringPtr(Int32& length)
       at System.Web.Hosting.IIS7WorkerRequest.GetQueryStringRawBytes()
       at System.Web.HttpRequest.get_QueryStringBytes()
       at System.Web.HttpRequest.get_QueryStringText()
       at System.Web.HttpRequest.BuildUrl(Func`1 pathAccessor)
       at System.Web.HttpRequest.get_Url()
       at SEOChecker.Core.Umbraco.Context.ContextInfo.Initialize(HttpContext context, Boolean editMode)
       at SEOChecker.Core.Umbraco.Context.ContextInfo..ctor(HttpContext context)
       at SEOChecker.Core.Components.ValidationqueueComponent.TimerCallback(Object sender)
  • Michael Chart 13 posts 94 karma points
    Oct 23, 2019 @ 12:59
    Michael Chart
    We are getting a similar error filling up the log. We are using Umbraco 8.1.4 and SeoChecker 2.8.2, not on Umbraco Cloud, but hosted on Azure.
    Exception:
    System.ArgumentException: Value does not fall within the expected range.
        at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
        at System.Web.Hosting.IIS7WorkerRequest.GetUserAgentInternal()
    Any idea what is causing these issues?
  • Arjan H. 226 posts 463 karma points c-trib
    Nov 05, 2019 @ 14:42
    Arjan H.
    I'm getting the same errors on a new self-hosted Umbraco 8.2.0 website using SEOChecker 2.8.2. Did you find out what was causing the issue?
    Nov 05, 2019 @ 16:09
    Michael Chart
    I haven't yet found a resolution. Perhaps @Richard can help us?
  • Giant Penguin 23 posts 112 karma points
    Nov 05, 2019 @ 18:31
    Giant Penguin
    Today, the SEOchecker throws a new error:
    SEOChecker: SEOChecker: Error converting DB values to editor values
    Exception
    System.NullReferenceException: Object reference not set to an instance of an object. at SEOChecker.Core.Umbraco.DocumentWrappers.UmbracoDocument..ctor(IContent doc, IContextInfo info, String culture, String segment) at SEOChecker.Core.Repository.Umbraco.UmbracoDocumentRepository.Single(Int32 id, IContextInfo context, String culture, String segment) at SEOChecker.DataTypes.PropertyEditors.PropertyEditorWrappers.SEOCheckerPropertyWrapper.ToEditor(Property property, IDataTypeService dataTypeService, String culture, String segment)
    Nov 06, 2019 @ 07:31
    Bo Jacobsen
    Hi Giant.
    I also have question about that here https://our.umbraco.com/packages/website-utilities/seo-checker/bugs/99114-error-converting-db-values-to-editor-values but i can't seem to find out what triggers it.
  • Richard Soeteman 4054 posts 12927 karma points MVP 2x
    Nov 09, 2019 @ 11:25
    Richard Soeteman
    Think this error is because of a missing HTTPContext, will check but hard to debug. Will come back to this.
    Best,
    Richard
    Nov 21, 2019 @ 12:42
    Arjan H.
    Hi Richard! Any news on this? This is what my Umbraco logs currently look like:
    This error seems to interfere with SEOChecker's basic functionality. There are currently no 301 redirects being generated when renaming content and 'Track url history' enabled.
    Nov 21, 2019 @ 16:24
    Richard Soeteman
    Hi Arjan,
    Unfortunatly not. Would love to debug this with some logging next week if possible?
    Best,
    Richard
    Nov 21, 2019 @ 17:17
    Arjan H.
    I'd be happy to help in any way I can. Let's schedule a Skype session some time next week so we can do some debugging. I'll send you an email to set something up.
    Nov 27, 2019 @ 15:38
    Arjan H.
    I just had a very productive Skype session with Richard. Richard managed to implement a hotfix for the 'Value does not fall within expected range' issue. I have deployed the hotfix to my production server and so far so good.
    You can download the patched dll's here: https://www.dropbox.com/s/rqjb7tmpnsft71r/seodll.rar?dl=0
    This patch will probably be included in release 2.9.0, but in the mean time you can use this hotfix. Just to be clear: I have applied the fix to version 2.8.2. The updated dll's should not affect any existing functionalities.
    Dec 03, 2019 @ 14:51
    Bo Jacobsen
    Hi Arjan.
    I tried to use the new dlls, it seems to remove the old errors, but now i get new errors.
    Message:
    Unhandled controller exception occurred for request '"https://www.xxx.dk/umbraco/backoffice/UmbracoApi/Content/GetById?id=2080"'
    Exception:
    System.ArgumentNullException: Value cannot be null.
    Parameter name: Cannot find a content type  with alias
       at SEOChecker.Core.Repository.Definition.DefinitionFactory.Single(String alias)
       at SEOChecker.Core.Config.Configuration.GetDocumentTypeByAlias(String alias, String doctypeAlias)
       at SEOChecker.Core.Config.Configuration.GetDocumentTypeByAlias(String alias)
       at SEOChecker.DataTypes.PropertyEditors.PropertyEditorWrappers.RobotsTxtPropertyWrapper.ToEditor(Property property, IDataTypeService dataTypeService, String culture, String segment)
       at Umbraco.Web.Models.Mapping.ContentPropertyBasicMapper`1.Map(Property property, TDestination dest, MapperContext context)
       at Umbraco.Web.Models.Mapping.ContentPropertyDisplayMapper.Map(Property originalProp, ContentPropertyDisplay dest, MapperContext context)
       at Umbraco.Web.Models.Mapping.ContentPropertyMapDefinition.Map(Property source, ContentPropertyDisplay target, MapperContext context)
       at Umbraco.Core.Mapping.UmbracoMapper.<>c__DisplayClass8_0`2.<Define>b__1(Object source, Object target, MapperContext context)
       at Umbraco.Core.Mapping.UmbracoMapper.Map[TTarget](Object source, Type sourceType, MapperContext context)
       at Umbraco.Core.Mapping.UmbracoMapper.Map[TSource,TTarget](TSource source, MapperContext context)
       at Umbraco.Core.Mapping.MapperContext.Map[TSource,TTarget](TSource source)
       at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
       at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
       at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
       at Umbraco.Core.Mapping.MapperContext.MapEnumerable[TSourceElement,TTargetElement](IEnumerable`1 source)
       at Umbraco.Web.Models.Mapping.TabsAndPropertiesMapper.MapProperties(IContentBase content, List`1 properties, MapperContext context)
       at Umbraco.Web.Models.Mapping.TabsAndPropertiesMapper`1.Map(TSource source, MapperContext context)
       at Umbraco.Web.Models.Mapping.ContentMapDefinition.Map(IContent source, ContentVariantDisplay target, MapperContext context)
       at Umbraco.Core.Mapping.UmbracoMapper.Map[TTarget](Object source, MapperContext context)
       at Umbraco.Web.Models.Mapping.ContentVariantMapper.Map(IContent source, MapperContext context)
       at Umbraco.Web.Models.Mapping.ContentMapDefinition.Map(IContent source, ContentItemDisplay target, MapperContext context)
       at Umbraco.Web.Editors.ContentController.MapToDisplay(IContent content)
       at Umbraco.Web.Editors.ContentController.GetById(Int32 id)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass6_2.<GetExecutor>b__2(Object instance, Object[] methodParameters)
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__6.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__5.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
       at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__6.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
    Dec 05, 2019 @ 13:07
    Bo Jacobsen
    And this happen when i try to access newly created documents or try to create new documents.
    Jan 23, 2020 @ 08:35
    Bo Jacobsen
    Hi Richard.
    Did you ever found a solution to this?
    I installed version 2.9.0 on a Umbraco 8.5.1 cloud website.
    An again i get alot of these errors.
    Jan 23, 2020 @ 09:28
    Bo Jacobsen
    I create a new topic. Since the error i get now is not exactly the same. And the last error was fixed in SeoChecker version 2.9.0
  • Remko 118 posts 283 karma points
    May 07, 2020 @ 12:28
    Remko
    We also have this bug in our (live) website (8.5.3)
    Client asks us to fix the error for a little while now, but unfortunately we can't give any reasonable answer...
    May 08, 2020 @ 06:18
    Richard Soeteman
    Hi Sorry,
    Think this was related to the ignored path error which is fixed in hotfix release below
    https://www.dropbox.com/s/g1jrjdsu47adttj/seo-checker29_1.zip?dl=0
    Hope this helps,
    Richard
    May 08, 2020 @ 09:24
    Remko
    Still the same exception:
    May 11, 2020 @ 09:35
    Richard Soeteman
    Any more info that got logged? The HttpContext should not be an issue anymore so could be a different area.
    May 08, 2020 @ 09:37
    Remko
    After adding Facebook App Id, I now get the following execption in log:
    System.NullReferenceException: Object reference not set to an instance of an object. at SEOChecker.Core.Helpers.UmbracoUrlHelper.<>c.
    May 11, 2020 @ 12:39
    Richard Soeteman
    Hi Remko,
    Think I fixed this one as well. Was indeed a null refernce exception
    Hotfix version https://www.dropbox.com/s/ioplivqtoyng4bp/seo-checker29_1.zip?dl=0 Hope it works on your end too.
  • Gareth Wright 32 posts 101 karma points c-trib
    May 21, 2020 @ 07:10
    Gareth Wright
    Richard, is this on nuget yet? We're experiencing the same problems on 2.8.2 on production and wanted to roll this out...
    Can we just update the DLL's from this hotfix?
    May 22, 2020 @ 06:51
    Richard Soeteman
    Think it's just Dll's indeed
    Aug 25, 2020 @ 07:45
    Bo Jacobsen
    Hi Richard.
    I got the exactly same error again on Umbraco Cloud 8.6.4, when using SeoChecker 2.9.1.
    Is there a way to turn of the Scheduled task?
    Aug 25, 2020 @ 07:47
    Richard Soeteman
    Hi Bo,
    At the moment not. Will and Fix this issue and add an option to disable automatic validation in 2.10.
    Aug 25, 2020 @ 07:48
    Bo Jacobsen
    Perfect Richard.
    When do you think the 2.10 release will be?
    Sep 01, 2020 @ 11:46
    Richard Soeteman
    Sorry ofcourse you can disable automatic validation.
    Set "Validate a page when published" on Validation settings and make sure Automatic validation mode is set to "Never validate automatically" on the Datatype configuration.
    Hope this helps disable automatic validation
    Aug 25, 2020 @ 07:50
    Richard Soeteman
    Should be next month, if (8.7 doesn't have too many breaking changes). Might have Hotfixes for these issues done earlier.
    Aug 25, 2020 @ 08:05
    Bo Jacobsen
    Great.
    I hope you let us know when a hotfix is ready :)
