  • Anders Aleborg 35 posts 67 karma points
    Jan 22, 2015 @ 14:57
    Anders Aleborg
    In footer?
    is it possible to place the twitter and facebook feeds in the Master template? With the current solution we have to authorize every single page on the website
  • Anders Bjerner 487 posts 2996 karma points MVP 8x admin c-trib
    Jan 22, 2015 @ 23:37
    Anders Bjerner
    Hi Anders,
    Yes, that is indeed possible.
    If you have the property on each page, I assume you're doing something like this in your template/view:
    // Get the OAuth information stored in the property
    FacebookOAuthData facebook = Model.Content.GetPropertyValue("facebook") as FacebookOAuthData;
    That takes the property on the current page.
    The fix
    In your content tree, you will have a node representing the site, so if you add the property here rather than on each page, you can update your code to something like:
    FacebookOAuthData facebook = Model.Content.AncestorOrSelf(1).GetPropertyValue("facebook") as FacebookOAuthData;
    The code will now take the current page, and then find its ancestor at level 1 (assuming that site node is the topmost node). You can put this code in your master template/view, our even isolate it further in a partial view.
    Hope this solves your problem ;)
    Jan 27, 2015 @ 10:42
    Anders Aleborg
    Thanks, that did the trick!
