How would I convert this so it works with Umbraco.Web.MVC.UmbracoTemplatePage? I want to be able to use CurrentPage.
@using Skybrud.Social.Twitter
@using Skybrud.Social.Twitter.Objects
@using Skybrud.Social.Umbraco.Twitter.PropertyEditors.OAuth
// Get the OAuth information stored in the property
TwitterOAuthData twitter = Model.GetPropertyValue("twitterFeed") as TwitterOAuthData;
// Check whether the OAuth data is valid
if (twitter != null && twitter.IsValid) {
// Gets an instance of TwitterService based on the OAuth data
TwitterService service = twitter.GetService();
// Get information about the authenticated user
TwitterUser user = service.Users.GetUser(twitter.Id).Body;
// Get recent status messages (tweets) from the authenticated user
TwitterStatusMessage[] recent = service.Statuses.GetUserTimeline(user.Id, 5).Body;
<fieldset>
@foreach (TwitterStatusMessage status in recent) {
<p>@status.Text</p>
</fieldset>
if (CurrentPage.HasValue("instagramSocial", true))
<p>@CurrentPage.instagramSocial</p>
I think it's really not necessary to use CurrentPage since you have Model now with the same capabilities? If you tell us what specifically do you miss from CurrentPage we can help.
Thanks for the reply. I am trying to access a document type which belongs to another page
i.e On my homepage, I have a 'Social media' tab, which holds my social media usernames, I want to be able to use the code above on other pages as well as the homepage but don't want to have to enter my social media details or create a 'Social media' tab on every page I create.
Alright, that's pretty similar to how you would do it with CurrentPage so it would look something like this:
var rootNode = Model.Content.AncestorOrSelf(1);
var twitterUserName = rootNode.GetPropertyValue<string>("twitterUserName");
To explain: Model.Content.AncestorOrSelf(1) means: from the current page (Model.Content) go up through the list of all of the ancestors and stop at level 1. That's presumably where your homepage lives.
Then find the property with alias twitterUserName on the homepage and get the string value of it as filled in on the homepage (rootNode).
Thanks Sebastiaan, but I am getting a compilation error:
CS1061: 'Umbraco.Core.Models.IPublishedContent' does not contain a definition for 'Content' and no extension method 'Content' accepting a first argument of type 'Umbraco.Core.Models.IPublishedContent' could be found (are you missing a using directive or an assembly reference?)
It is highlighting the line
var rootnode = Model.Content.AncestorOrSelf(1);
I'm uinheritting Umbraco.Web.Mvc.UmbracoViewPage, do I need anything else?
Ah, alright, I see what's going on. So you haven't explicitly been given the content. Alright, should be easy to fix:
To get to the content like I listed above use the following:
var currentContent = Umbraco.TypedContent(UmbracoContext.PageId.Value);
var rootNode = currentContent.AncestorOrSelf(1);
I think Sebastiaans initial code example was right, but you probably need to integrate it a bit into the view depending on which class you're inheriting from.
If you can post your entire cshtml file, we can work on from there ;)
Layout = null;
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<meta name="description" content="">
<meta name="author" content="">
<title>@Umbraco.Field("pagetitle")</title>
<!-- Bootstrap Core CSS -->
<link href="/css/bootstrap.min.css" rel="stylesheet">
<!-- Custom CSS -->
<style>
body {
/* padding-top: 70px; */
/* Required padding for .navbar-fixed-top. Remove if using .navbar-static-top. Change if height of navigation changes. */
</style>
<link href="~/css/style2.css" rel="stylesheet" />
<link rel="stylesheet" href="//maxcdn.bootstrapcdn.com/font-awesome/4.3.0/css/font-awesome.min.css">
<!-- HTML5 Shim and Respond.js IE8 support of HTML5 elements and media queries -->
<!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/libs/html5shiv/3.7.0/html5shiv.js"></script>
<script src="https://oss.maxcdn.com/libs/respond.js/1.4.2/respond.min.js"></script>
<![endif]-->
</head>
<body class="home page page-id-39 page-template page-template-page-custom page-template-page-custom-php custom-background-empty custom-font-enabled single-author l-wide">
<header id="masthead" class="site-header" role="banner">
<nav id="site-navigation" class="main-navigation navbar navbar-default navbar-static-top" role="navigation">
<div class="container">
<!-- Brand and toggle get grouped for better mobile display -->
<div class="navbar-header">
<button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#bs-example-navbar-collapse-1">
<span class="sr-only">Toggle navigation</span>
<span class="icon-bar"></span>
</button>
<a class="navbar-brand" href="/">RunningBeside.me</a>
<!-- Collect the nav links, forms, and other content for toggling -->
<div class="collapse navbar-collapse" id="bs-example-navbar-collapse-1">
@Umbraco.RenderMacro("siteNav")
<!-- /.navbar-collapse -->
<!-- /.container -->
</nav>
</header>
<div id="primary" class="site-content">
<div id="content" role="main">
@RenderBody()
<footer id="colophon" role="contentinfo">
<div id="supplementary">
<div class="row2">
<div class="col-md-4">
<div id="first" class="widget-area" role="complementary">
<aside id="text-2" class="widget widget_text">
<div class="textwidget">
<img style="margin-bottom:25px; margin-top:7px;" src="/Css/images/branding.png">
<p>Mandy and Owain Williams run in and around Edinburgh, Scotland. Running all distances from 1 mile to marathons. </p>
<p>This site gives you a glimpse in to where they train, race and run. They try and blog as much as possible, but running always comes first!</p>
</aside><aside id="social_links-widget-2" class="widget social_links">
<h3 class="widget-title">Stay Connected</h3> <ul class="social-links ">
<li>
<a class="facebook" href="@Umbraco.Field("facebook", recursive: true)" target=""><i class="fa fa-facebook"></i></a>
</li>
<li>
<a class="twitter" href="@Umbraco.Field("twitterSocial",recursive: true)" target=""><i class="fa fa-twitter"></i></a>
</li>
<li>
<a class="instagram" href="@Umbraco.Field("instagramSocial",recursive: true)" target=""><i class="fa fa-instagram"></i></a>
</li>
</ul>
</aside>
</div><!-- #first .widget-area -->
<div id="second" class="widget-area" role="complementary">
<aside id="featured-posts-2" class="widget widget_featured_entries">
<h3 class="widget-title">Recent Tweets</h3>
@Html.Partial("twitterFeed")
</aside>
</div><!-- #second .widget-area -->
<div id="third" class="widget-area" role="complementary">
<h3 class="widget-title">Instagram</h3>
@Html.Partial("instagram")
</aside>
</div><!-- #third .widget-area -->
</div><!-- #supplementary -->
<center>@Umbraco.Field("footerText", altText: "Copyright ", recursive: true)</center>
</footer>
<script src="/js/jquery.js"></script>
<!-- Bootstrap Core JavaScript -->
<script src="/js/bootstrap.min.js"></script>
</body>
</html>
instagram partial:
@using Skybrud.Social.Instagram
@using Skybrud.Social.Instagram.Objects
@using Skybrud.Social.Instagram.Responses
@using Skybrud.Social.Umbraco.Instagram.PropertyEditors.OAuth
InstagramOAuthData instagram = Model.GetPropertyValue("instagram") as InstagramOAuthData;
if (instagram != null && instagram.IsValid) {
// Gets an instance of InstagramService based on the OAuth data
InstagramService service = instagram.GetService();
// Gets information about the authenticated user
InstagramUserResponse self = service.Users.GetSelf();
// Get recent media from the authenticated user
InstagramRecentMediaResponse recent = service.Users.GetRecentMedia(self.Body.Data.Id, 4);
<fieldset>
@foreach (InstagramMedia media in recent.Body.Data) {
<a href="@Umbraco.Field("instagramSocial")"><img src="@media.Thumbnail" alt="@media.CaptionText" height="110px" width="110px" /></a>
</fieldset>
I would use it for a twitter partial as well but if I can pull the data from one field then I can do it for all of them.
As a side note, what's the best way to learn about all of this, other than the forum?
It really does work though :-)
In your Instagram partial, after @{ something like:
InstagramOAuthData instagram = rootNode .GetPropertyValue("instagram") as InstagramOAuthData;
Maybe this even works:
var instagram = rootNode.GetPropertyValue<InstagramOAuthData>("instagram");
Using UmbracoTemplatePage instead of ViewPage
Hate to bump this but really want to the use of CurrentPage with this. Hope someone can help as I can't work it out.
CurrentPage
since you haveModel
now with the same capabilities? If you tell us what specifically do you miss fromCurrentPage
we can help.Hi, Thanks for the reply. I am trying to access a document type which belongs to another page
CurrentPage
so it would look something like this:To explain:
) go up through the list of all of the ancestors and stop at level 1. That's presumably where your homepage lives.Then find the property with alias
twitterUserName
).Thanks Sebastiaan, but I am getting a compilation error:
Hi Owain,
Hi, Thanks for your help!
Here is all my code.
Master template:
instagram partial:
Thanks!
It really does work though :-) In your Instagram partial, after
something like:Maybe this even works:
Brilliant! It was the second part to your reply that made it work for me!
I think it's lack of understanding that I'm struggling with most - might look at a Umbraco.TV subscription and see if that helps me with the basics.
Thanks for your help.
