You're totally correct. It should work like that. It seems that I have replaced the view for the property editor with the view from the prevalue editor.
For a hotfix, you should be able to replace the property editor with the contents of this file (it is an older version of how the file should look):
The issue was common for both the NuGet, GitHub and Umbraco releases since I had messed up the view, and somehow hadn't tested the latest release good enough.
Trouble with Twitter OAuth
I am working on getting a twitter feed connected and I am having an issue with it. I have created the data type just fine shown in this first image...
Now when I add the data type to the doc type and then go to the content item that the doc type is associated with, I get the following screen...
Shouldn't I get an authorize screen like I do for facebook and instagram. Those are also using the Skybrud.Social for Umbraco data types.
Thanks!
Hi Aaron,
https://github.com/abjerner/Skybrud.Social.Umbraco/blob/d4785abdc83e75da99719503785806fbc9f27a29/src/Skybrud.Social.Umbraco/App_Plugins/Skybrud.Social/Twitter/OAuth/PropertyEditor.html
I will look into fixing this in the repository as well, and push a new release ;)
Thanks for your quick reply. I did get this through NuGet as well just in case that helps.
Your workaround did work as well. Thanks again.
Anyways, new NuGet release is here: https://www.nuget.org/packages/Skybrud.Social.Umbraco/1.0.6
