  • Neil Hodges 338 posts 987 karma points
    Dec 09, 2020 @ 13:25
    Neil Hodges
    Product Bundle - Same Product Id per bundles Item not being added
    I'm trying to bundle products together by the size of the garment. It doesn't seem to want to bundle multiple products with the same productId.
    What I have so far when adding to the basket:
     if (model.Sizes != null)
                var sizes = model.Sizes.Where(x => x.Value > 0);
                if (sizes.Any() == true)
                    var bundleId = Guid.NewGuid().ToString();
                    var indx = 0;
                    foreach (var size in sizes)
                        properties[WConstants.OrderLines.Size] = size.Key;
                        if (indx == 0)
                            TC.AddOrUpdateOrderLine(store.Id, model.ProductId, size.Value, properties, bundleIdentifier: bundleId);
                        else
                            TC.AddOrUpdateOrderLine(store.Id, model.ProductId, size.Value, properties, parentBundleIdentifier: bundleId);
                        indx++;
            else
                TC.AddOrUpdateOrderLine(store.Id, model.ProductId, 1, properties);
    This produces: enter image description here
    1) Is the first Main Product, this will be the master where the others will be bundled against.
    2) Is the last in the sequence, it seems to just add them all together and take on the last size, L, there should be 5 x XS, 5 x S, 5xM and lastly 5xL
    Ive set Product uniqueness property aliases to below: enter image description here
    Can it only bundle products of unique product ids?
  • Matt Brailsford 4125 posts 22224 karma points MVP 9x c-trib
    Dec 09, 2020 @ 13:36
    Matt Brailsford
    Hi Neil,
    I think this might be a similar bug that we found in Vendr, that the bundle ID isn't taken into account for uniqueness. For a quick workaround, you could add the bundleId as a property to the order line, and then use that property as a uniqueness property too. This should then treat them as separate order lines.
    We'll need to look at making an update to take bundle ID's into account, but the above workaround should be safe to apply and it would continue to work once the fix is in place.
    Hope this helps
    Matt
    Dec 09, 2020 @ 14:30
    Neil Hodges
    HI Matt
    Ive altered the code to:
                    properties.Add("bundleId", bundleId);
                        TC.AddOrUpdateOrderLine(store.Id, model.ProductId, size.Value, properties);
            else
    So it just adds the products to the order with the 'bundleId' as a property.
    Then made sure my property type is using the unique key enter image description here
    But i seem to be getting them added together, OrderLine is set at 1.
    Am I doing something wrong when AddOrUpdateOrderLine? Do they still need a bundleIdentifier?
    By the way, this is using TC 3.4.4
    Dec 09, 2020 @ 14:45
    Matt Brailsford
    Hey Neil,
    Sorry, you still want to use the bundleId as a bundleId, but you also want to use it as a property, so you need to do both.
    Hope this helps
    Matt
    Dec 09, 2020 @ 15:11
    Neil Hodges
    Yeh tried a couple of diffrent combinations but it wont add them. It seems the Bundle and Uniqueness of the product are not being obeyed.
            else
    It just gives me 1 x OrderLine and adds all the qty together? Scratching my head with this one, not sure why it wont add them as seperate orderLines?
    Dec 09, 2020 @ 15:25
    Neil Hodges
    hmm, seems if i add another unique property it works :) enter image description here
    I guess now i can just group them by the Bundle Identifier to show them as under one order :)
    Cheers Matt.
    Dec 09, 2020 @ 15:33
    Matt Brailsford
    Hey Neil,
    It might be because they are sharing the same bundleId. You need to make sure that every call to add an order line has a unique bundleId. I think here, your bundle ID is repeated per size option.
    Matt
    Dec 09, 2020 @ 15:49
    Neil Hodges
    Yeh, I moved the generation of the bundle Identifier into the for each loop, creating a new GUID each loop.
    But just got an error:
    An item with the same key has already been added.
    Dec 09, 2020 @ 15:52
    Neil Hodges
    I guess its the
    part, as that key is already added,
    I think this would then work:
                    var bundleIdentifier = Guid.NewGuid().ToString();
                    properties.Add("bundleId", bundleIdentifier);
    Dec 09, 2020 @ 15:56
    Matt Brailsford
    I think really each call to TC.AddOrUpdateOrderLine should have it's own properties collection created, as currently you are reusing the properties for each call, hence the error.
    Matt
    Dec 09, 2020 @ 16:05
    Neil Hodges
    Nice one Matt, all sorted! :)
