  • MrFlo 159 posts 403 karma points
    Jan 05, 2012 @ 15:17
    MrFlo
    Add to cart problem
    TeaCommerce seems very promising!
    But I can't have the add to cart button working with JS.
    The post to the page http://mydomain.fr/tcbase/teacommerce/AddOrderLine/1081/1.aspx is always giving me a file not found exception (after tracking in Firebug)
    Do I have something wrong in my config files ?
    Thank you,
    MrFlo
  • Anders Burla 2560 posts 8256 karma points
    Jan 05, 2012 @ 15:56
    Anders Burla
    Hi MrFlo
    Did you just install Tea Commerce or did you use the starter kit? Try and check your web.config for a Tea Commerce http handler. Does it say teaCommerceBaseRequestModule anywhere? If not - be sure the application pool process running the site has modify rights for the website folder and then install Tea Commerce again.
    Kind regards
    Anders
    Jan 05, 2012 @ 16:14
    MrFlo
    Hi Anders,
    Thanks for your quick answer. I appreciate! I am using the from scratch version and I am trying to follow the tutorial. there were no teacommerce handler in my web.config.
    I have just reinstall teacommerce over the existing one and then the web.config was updated. It works now! So no access problem.
    Strange that it didn't work the first time.
    Thanks a lot!
    MrFlo
    Jan 05, 2012 @ 16:20
    Anders Burla
    Your welcome - happy to help - and glad it was just because of the web.config not being updated.
    Kind regards
    Anders
