What have I cut and shut out to stop this working ? (ignore the fact the price is different to in the drop down it's me messing about with a vat thing)
Yes, now your problem is that you rely on url parameters, which cannot be sent to the invokeXslt method. You can send a nodeId , which usually is the product variant node.
Are your products and variants normal umbraco content nodes?
Hmmm this was a desision by the client to have two sections on his site, one with all his products and one with shop oninle which are basically products he added prices to.
This was to allow him at any time to put a product into the shop without adding new content ect.
So the shop online section is a bunch of different templates that reply on a the querystring for the node so instead of $currentPage we use the querystring N
It worked brilliantly till he then wanted vatrients....
I can ignore the AJAX bit feature the prices in the drop down and on the page if not varient... I was just trying to see if I could get it to work. So how could I get thatpage to ignore it without the javascript error ?
Ok. Then we just have to find a solution. It's Tea Commerce, so everything is possible ;-)
One way would be to reload the page with a new querystring parameter. You would have to change the script that runs when the drop down is changed. This would be quite simple.
ha haa how simple. I have got this far I think i am too close to it.
I am not the best developer in the world and have got this far by basically being lucky and the fact that teacommerce is fundamently easy to use with the way umbraco works.
Yeah I don't know where I am looking at...what is causing the Not Enough parameters in url.
is it this bit ?
function updatePageUI() { /* All xslt's that can be invoked in this way have information in a div with the class "invokeXSLT". For every one of them we update the UI. */ jQuery('div.invokeXSLT:not(div#products div.product div.invokeXSLT)').each(function () { var invokeXSLT = jQuery(this), parent = invokeXSLT.parent(), productid = parent.attr('productid') || _nodeId; htmlFromServer = TeaCommerce.invokeXSLT(invokeXSLT.text(), productid, { umbracoLanguageId: _languageId, async: false }); parent.before(htmlFromServer).remove(); }); }
I have put <input name="ReturnUrl" type="hidden" value="/shop-online/shopcategory/shopsubcategory/shopproduct.aspx?n={$fN/@id}" />
so it returns to the right page but perhaps that's unessesary ?
You should change this piece in the teaCommerce_simple.js
/* Will update one product element. We only do this because the variants have different stock and prices than the main product. */ function updateProduct(productEle) { var variant = productEle.find('select.productVariants').val(), chosenProductId = variant ? variant : productEle.attr('productid'), xsltFile = productEle.children('.invokeXSLT').text(), htmlFromServer = TeaCommerce.invokeXSLT(xsltFile, chosenProductId, { umbracoLanguageId: _languageId, async: false }); productEle.before(htmlFromServer).remove(); }
Self induced AJAX problem, I think.
Hey Teacommerce
Once again I have chopped and changed your package so much I have chopped something out I needed..
When you have a variant in the demo webshop and the price in the brown changes automaticially as the variant drop down is selected...
Which bit's doing this ? what does it rely on to work you can see an example of it working here on a demo webshop as first installed.
http://www.lunch-break.co.uk/en/products/category-a/product-a1.aspx
and not working here on a site I have built with the demo webshop but been a bit gung ho with my ammends...
http://aitkens.voltagedev.co.uk/shop-online/shopcategory/shopsubcategory/shopproduct.aspx?n=1222
Cheers
Doogie
Hi Doogie,
You are missing the _languageId variable in the MainMaster master template. It's used by the Tea Commerce invokeXslt method, that refreshes the UI.
Try using the firebug console when changing the variant in the dropdown. It shows you the javascript error.
/Rune
Ahh I think the problem is deeper then I have added the code and it errors in a whole new way.. I think I have changed the structure too much.
Doogie
/Rune
Doogie
/Rune
Doogie :)
Yeah, sometimes the simplest solutions eludes the developer. :)
Looking forward to see the website up and running. Please mark my answer for others to see (If it's a good enough answer for you)
/Rune
is it this bit ?
async: false
async: false
dare I ask to what... so sorry :) Just head is screwed looking at it all again.
I take it I need that code to incorporate the query.
I guess I am asking if there is not enough url parameters... what's missing :) and how do I send it.
Doogie.
Hi Doogie,
Sorry I couldn't get to answer your comment. Have you found out yourself or do you need a few pointers?
/Rune
