  • PRK 47 posts 119 karma points
    May 19, 2014 @ 10:44
    PRK
    TeaCommerce 2.3.0 IE Problem - Cart is always empty
    Hy all,
    I've installed Teacommerce 2.3.0 for Umbraco 6. In IE the cart is always empty, also the Mini-Cart never shows an Item. My first step was to create a new Umbraco Instance and installed the Starter Kir from your website. The same Problem. Are there any Javascript problem?
  • Anders Burla 2560 posts 8256 karma points
    May 19, 2014 @ 12:37
    Anders Burla
    Is the problem only in IE? If yes - which version? The starter kit is a standalone complete solution and can not be installed like a normal Umbraco package.
    Kind regards
    Anders
    May 19, 2014 @ 12:48
    PRK
    I have the problem in IE7,IE8,IE9,IE10,IE11. In Firefox all working well.
    1. click on Add to cart
    2. Mini Cart shows item and price
    3. Click on View Cart on Mini Cart or Clicking any other Page - > Cart and Mini Cart are empty
    May 19, 2014 @ 12:50
    Anders Burla
    Does this page work? It works in my IE:
    http://starterkit.teacommerce.net/
    May 19, 2014 @ 13:03
    PRK
    Thats very confusing. It doesn`t work on my System and I have no error. So I ran to all our other systems and tested the link -> it works. If no other client of your shop has reported the problem, I think I can live with it (because I never use the IE).
