    Mar 24, 2015 @ 12:19
    Ismail Mayat
    Max order setting
    I am using Umbraco 4.7.0 and therefore an old version of teacommerce not sure which version but teacommerce.dll states version 1.0.0.1634.  Is there a max order purchase price setting somewhere? Client is reporting they cannot order anything greater than £2448. I have had a look in settings but cannot see anything, any ideas?
    Regards
    Ismail
  • Anders Burla 2560 posts 8256 karma points
    Mar 25, 2015 @ 09:19
    Anders Burla
    Hi Ismail
    I don't think it should have that. Could you try and check in the DB what type the price is saved as i v1. But sounds a bit weird with that specific price :)
    Kind regards
    Anders
    Mar 25, 2015 @ 11:34
    Ismail Mayat
    Anders,
    I have more information from the client see attached image, the actual error is below, it looks like the unit price which is 5.99 and is less than 10 is causing the issue?
    e?
    Mar 25, 2015 @ 11:40
    Anders Burla
    That javascript alert is not anything Tea Commerce does - it is in the customer implementation.
    I can see that the UI sometimes user . and other times , - maybe the formatting isnt using the build in Tea Commerce functions?
    Kind regards
    Anders
    Mar 25, 2015 @ 12:12
    Ismail Mayat
    Anders,
    Aha ok no worries i will dig further at least I now know where to look.
    Ismail
    Mar 26, 2015 @ 18:51
    Ismail Mayat
    Anders,
    Fixed this, was parsing float but string number had , doh!!
    Regards
    Ismail
    Mar 27, 2015 @ 08:12
    Anders Burla
    Ha ha - that kind of thing :)
